Re: Tractor listed incorrectly on Ebay......
Posted by Larry B. 1486 on December 04, 2010 at 11:15:22 from (67.142.161.18):
In Reply to: Tractor listed incorrectly on Ebay...... posted by RTR on December 03, 2010 at 18:33:24:
It's a B450. I had one for about twelve years back in the 70's and early 80's. That is a row crop B450 as the serial number tag will say B450 RC( row crop ) and then the serial number. From the front you thinking you are looking at a American Farmall SM. I still have the owners manual and parts book for it. The hyd pump was mounted up front and two steel lines ran to the back. It was one hell of a tractor but very hard to start. Factory 3pt hitch and differental lock. The pictures in my books show the head lights mounted on the front hood, grill, but mine had them on the post like a Farmall M. My SMD was rated at the same hp as the B450, 52 hp, but the SMD WOULD not keep up with the B450. The front and rear wheels were the same as my SMD also. This one on ebay, I could not find where it tells is located at.
