Posted by Janicholson on December 05, 2010 at 12:53:43 from (67.72.98.45):
In Reply to: H distributer posted by JKH on December 05, 2010 at 10:05:36:
All distributor from Hs and Super Hs will bolt right on where the Mag is now. Almost all 4 cylinder IH distributors will also work if you change the centrifugal advance springs, and advance stop limit. They will work without changes, but the total advance and curve will be off. The ignition switch will need to be changed (the current switch is a grounding "kill" switch). A new wire from the load side of the Amp meter will be the source of voltage to the switch, and from the switch to the coil negative side. (positive ground system. Jim
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
