Re: How to find a good 6 Volt battery for $5
Posted by Wardner on December 05, 2010 at 14:50:47 from (4.154.253.98):
In Reply to: How to find a good 6 Volt battery for $5 posted by WSJ on December 05, 2010 at 11:54:30:
I bought a pair of new Interstate deep-cycle blemished batteries for my '98 Dodge Cummins three years ago. They were $40 ea from the Interstate warehouse.
I assume the golf cart batteries have the same construction. Most said they they wouldn't be satisfactory because they wouldn't have the required cold cranking amps.
Well, they work so well I took the extra battery from the Dodge 3500 and put it in my 660D. Both vehicles start fine on one deep-cycle storage battery even though both were equipped from the factory with duals.
Those deep-cycle batteries are very heavy and I suspect they will last a long time. They have fewer plates but those plates are considerably thicker and more durable. Probably similar to motorcycle batteries that can handle alot of heat and vibration.
I doubt if I will ever buy another automotive style battery.
