Re: 340 utility brakes
Posted by Moondoggie on December 05, 2010 at 15:38:22 from (66.187.36.156):
In Reply to: 340 utility brakes posted by wegge on December 04, 2010 at 15:27:49:
Yes, there is an oil seal on the shaft. If it leaks, the discs become saturated with oil. I replaced mine and the brakes work fine. With some patience and luck, you can remove and replace the seal without removing the shaft. good luck!
