Re: Super C Problem - Wardner you are needed here.
Posted by farmallhal on December 05, 2010 at 18:53:34 from (76.2.182.168):
In Reply to: Super C Problem ? posted by Farmall Dann on December 05, 2010 at 16:15:24:
I believe the easiest way to do what you want you will need a remote auxiliary control valve that is commonly used for the fast hitch tractors. I don't know how your tractor is configured but you will need to tap into the pressure lines coming from the engine driven hydraulic pump somewhere. I've seen a bypass block used as well but unless your SC has the fast hitch feature you will probably need to find the remote valve and different hydraulic lines to plumb it in. There are other ways and maybe Wardner will see your post as he seems to be a master with engineering hydraulic systems for unbelieveable uses. My email is open if you need other info or clarification for your proposed application, Hal.
