Re: Cub Engine Knock
Posted by tomato frank on December 05, 2010 at 19:49:40 from (67.77.188.149):
In Reply to: Cub Engine Knock posted by RD McClen on December 05, 2010 at 17:40:29:
hello,it just so happens i just took pistons and rods out of a cub last week.the guy i got it from said about the same thing,except he thought #1 was the problem.well #3 rod was blue and the crank journal was wiped out.i would check them all.i will grind crank if possible or replace,as far as rods go i will recon or replace.make sure that you clean oil galleys well also.wrist pin bushing must be checked as well.there"s my thought on that. good luck
