Re: how to tell if tires have tubes
Posted by mkirsch on December 06, 2010 at 05:26:47 from (64.80.108.56):
In Reply to: how to tell if tires have tubes posted by realolman on December 05, 2010 at 15:17:06:
You should have specified front or rear tires.
Since you mention fluid, you must mean REAR tires.
The valve stem should be attached to the rim with a nut, whether tubed or tubeless.
I have never seen a tubeless rear tractor tire, but I suppose such a thing could exist...
