Re: Cracked Block In Farmall B
Posted by Owen Aaland on December 06, 2010 at 06:08:56 from (65.165.246.162):
In Reply to: Cracked Block In Farmall B posted by Farmall-H on December 05, 2010 at 13:30:38:
Does the engine run alright otherwise, and are you concerned about how the engine looks?
If the engine is fine otherwise it is possible to bolt a patch over the crack. Fit a steel plate and gasket material over the crack and then drill and tap holes every couple of inched to fasten it to the block. There is a 340 around here that has been running like that for over 40 years.
