Re: 450 Radiator sucessfull
Posted by Mine had studs on July 01, 2000 at 11:00:27 from (207.177.47.144):
In Reply to: 450 Radiator sucessfull posted by Kenneth Harris on June 29, 2000 at 04:27:23:
Ken- My 450 uses studs. It has a rubber cushion washer between the radiator and the steel frame. I cut up a radiator hose and made new cushions. Underneath, first thing on the is coil spring, on that is a flat washer, last on is a self locking nut. The studs keep the thing from shifting around and the springs and rubber cushions let it flex as needed. Thanks for your posts, IHank
Post A Followup
: Re: Re: 450 Radiator sucessfull
