Re: Looked at tractor today...generator problems. Expensi...
Posted by tempola on December 06, 2010 at 14:52:09 from (75.121.252.205):
In Reply to: Re: Looked at tractor today...generator problems. Expensi... posted by billde on December 06, 2010 at 13:18:50:
because a automotive type alternator will not tolerate positive ground.
believe it or not, your starter will run the same direction on negative ground.
