Posted by tempola on December 07, 2010 at 09:38:25 from (72.161.222.149):
In Reply to: Super C Problem ? posted by Farmall Dann on December 05, 2010 at 16:15:24:
yes... there are conversion kits on e-bay.
BUT......the fluid capacity of the touch control system is very limited. If you try to run a really big hydraulic cylinder, the system will actually run out of fluid before it completes it's stroke. then if you fill it, there has to be somewhere for the excess to go when the cylinder closes. if not, it will blow the seal in the pump, and dump fluid into the engine oil pan.
you can screw a water pipe into the filler hole and then attach that to a residue (aux) tank. I had to do this when I was operating a dump bed wagon.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
