Re: Farmall B (please take it)
Posted by Hendrik on December 08, 2010 at 07:35:32 from (194.53.253.51):
In Reply to: Farmall B (please take it) posted by Farmall-H on December 07, 2010 at 15:15:42:
Are you sure your block is cracked? Had water in the crankcase of my Super A and it turned out that there was a leak at the bottom of a sleeve where the O-ring sits. The lower end of the (wet)sleeve was badly corroded. (When we started sandblasting the outside of the sleevewe blew a 1/4 inch hole in it...) So an overhaul will fix your leak.
HTH, Hendrik
