Re: Diode for alternator wiring - Which one is correct (p...
Posted by Janicholson on December 08, 2010 at 10:31:06 from (199.17.6.126):
In Reply to: Diode for alternator wiring - Which one is correct (picture) posted by AL Farmall Boy on December 08, 2010 at 09:55:08:
One milliamp is 1/1000 amp. The diode needs to handle about 150ma. I like a one amp diode just to be robust. Either of those should work they just might be closer to a spark or stray current breakdown. The PIV peak inverse voltage rating in more important to guard against the failure. 250 volts would be about right as it is connected in the ignition circuit (usually) and these are noisy. Jim
