Jim has ya well covered and I (as usual) agree with his excellent advise, but FWIW I dont really recommend diodes anymore, I say use EITHER at least a 10 (or up to a 100 will work) ohm 5 watt resistor ORRRRRRRR an incandescent (NOT LED too much resistance) dash type small idiot/indicator light. The light or resistor affords some degree of current limiting protection better then a diode would and the light gives you a toofer as it excites the alternator PLUS provides a good visual indication of whats going on. Either still prevents backfeeding the ignition as the diode does.
Of course you dont need a 5 watt resistor, a smaller wattage rating would suffice, but they usually have bigger more robust easier to wire up leads
Some "dudes" even wire a resistor in paralell with the idiot light so if the lamp burns out the alternator still gets excitation wooooooo hoooooooo
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
