Re: Paulson loader on M ,lowering control
Posted by D Slater on December 08, 2010 at 20:04:49 from (184.15.15.199):
In Reply to: Paulson loader on M ,lowering control posted by Super H Mike on December 06, 2010 at 12:36:49:
Thats the way a lot are. To lower the loader a check ball that holds the hydraulic oil from going back has to be pushed off its seat. When a heavy load is on the loader or a heavy loader the oil pressure trying to run back to the reservoir holds the ball harder. Lots of times it takes so much push pressure on the lever to release that it goes all at once. If just using one line from the pump with a tee to cylinders. Try hose on the rear port left side and see if its better. You will be using a different check circut that may be in better condition.
