Getting the pump out is simple but really needs to people as it is quite heavy. You have to take off the outside fittings and the handle. There will be a cover between the pump and the transmission - when you remove it you will see the coupling that drives the pump. Remove that and all thats left is the 4 bolts that hold the pump in place. I've found a hydraulic floor jack works well to raise and lower the pump. Use a second person to steady it. Concerning oil leaks there is a seal on the shaft and a gasket on the 2 halves and thats about it for places to leak.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
