Re: Farmall M Lift All Pump Removal
Posted by Stemmy on December 09, 2010 at 17:14:50 from (57.68.69.2):
In Reply to: Farmall M Lift All Pump Removal posted by Stemmy on December 09, 2010 at 16:54:30:
ok I thought thats all that was involved in it from what I read about the H's. I apprectiate your info! Im guessing get new seals from NAPA?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
