Re: Farmall M Lift All Pump Removal
Posted by Owen Aaland on December 09, 2010 at 17:16:32 from (65.165.246.162):
In Reply to: Farmall M Lift All Pump Removal posted by Stemmy on December 09, 2010 at 16:54:30:
The coupler can be removed on the H but on the M the coupler is shorter and must be removed as the pump is lowered.
Turn the pump drive shaft until on of the slots is vertical and then lower the pump. When the coupler is clear of the shaft it can be removed.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
