to add to charlies post, you need to turn the drive coupling so one half of it points vertical. its basically a real thick flat washer with two raised areas, like a cross. also when in there replace the seal on the drive dog that comes out of the trans. check the trans input shaft seal too, if its leaking, change it now. when you separate the pump from the resevoir, you can slide a small bar to lock the pump gears to spin off the pump drive to change the seal. when putting the pump back on the resevoir, be sure to get the little fork hooked up to the bracket that actuates the pump from the control rod. if you get it hooked, the control rod wont work and you will need to drop the belly pump again.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
