Re: 766 water problem
Posted by Owen Aaland on December 09, 2010 at 17:34:57 from (65.165.246.162):
In Reply to: 766 water problem posted by kennell on December 09, 2010 at 15:41:53:
HyTran is designed to absorb up to 3 percent water and keep it in suspension. That keeps the moisture from collecting on gears and bearings and causing them to rust. the downside is that in sub freezing temperatures this water will freeze to form ice crystals that will not go through the filter or bypass screen. Since the water stays suspended in the oil you can't just drain it off the bottom to separate it.
