Re: 766 water problem
Posted by Erik Dekeyser on December 09, 2010 at 18:05:15 from (216.208.200.43):
In Reply to: Re: 766 water problem posted by kennell on December 09, 2010 at 16:44:53:
You can only drain the water after the tractor has been sitting for about a day at least.And it has to be warm enough so the water in the tranmission isnt froze. The best time time to do that is in the spring or in the fall before it gets cold. The best place to drain it is at the very bottom of the tranmission. Just loosen the plug and let it out slow until it turns to oil.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
