Another trick is to put the jack up to the pump and leave the fill pipe on with the cap take the 4 bolts out on the bottom and let the jack down till the cap just about touches then take the cap off and put a rod down the pipe and let the jack down and you can do it all alone because the rod will hold the pump from tipping. Bob
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
