Posted by ScottyHOMEy on December 09, 2010 at 20:11:04 from (70.105.240.151):
In Reply to: Re: Cub hydraulics posted by Dave H (MI) on December 09, 2010 at 18:28:42:
A tip about that, now that you've got it apart. A bona fide sharp-edged scraper, a razor-blade scraper, with lots of spare blades, and anything else you've got with a finepoint or an edge will be your friend when it comes to removing that gasket and making sure you got it all off.
It's kinda like the gasket under the oil filter canisters, only worse. It will take on the finish and appearance of the metal it bonded to and will seem durned near as hard. When I popped the head off the hydro on my SuperC, I might never have known it was there, if it weren't for the parts catalog and the fact that in a couple of places the two sides of the gaskets separated from each other, leaving a fuzzy spot as a clue that the gasket was there at all.
It will be hard enough that it's tough to get anything to bite into it, thus my suggestion for pointy and very sharp things. Since you will be CLEANING things up very well as you go along, especially as you get to the reassembly, an aerosol gasket remover can be helpful, but use a piece of cardboard or something of that ilk in the other hand to mask off as you spray, so as to not get any more than absolutely necessary into any hard to clean spots.
Another tip as far as keeping things CLEAN as you go . . . As I laid things out to keep them in order and then reassemble, my practice was to tape some white butcher paper, with the plastic-coated side up, to the bench surface. As parts were cleaned, they were next wiped down with a rag moist, not soaked, with HyTran, and then staged atop the paper. If there was anything left for problematic dirt or debris left on them, it would show up on the paper and be dealt with. Plan on changing the paper as many times as necessary. Even lint can be a problem, so anything for a good lint-free rag will serve well, and the butcher paper is white enough to enhance whatever you have for light and show up any darker particles, and plastic-side-up keeps your surface white.
What with the similarity in our weather and heat in our shops, you may find that the final cleanup and reassembly will go much better if performed on the dining room table or a suitable counter in the kitchen. An unspoken factor in that approach would be the similarity or lack thereof in the natures of our chosen and dearest companions in life. First order of business is to send Mrs H. to a city, not a nearby town, with a shopping list that includes two tubes of relative bearing grease, and a 5-gal pail of sailboat fuel, along with several suggestions for retailers that might offer such things. Have your work staged so that you can bring it indoors as soon as she gets around the corner. Organization is the first key -- you'll have to be prepared to work fast. The second key is to have a batch of brownies or chocolate chip cookies ready to pop into the oven, starting about 45 minutes before you anticipate her return. Peanut butter cookies don't provide enough olfactory cover, it takes chocolate to cover the smell of mechanical juices. And don't forget the butcher paper.
As far as the daughters, you'll have to make the call as to whether they go with Mom. If they can be trusted to stay home and help, they should concoct an excuse for staying that has something to do with cleaning their rooms.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
