Re: Farmall M Lift All Pump Removal
Posted by Faster346 on December 09, 2010 at 21:08:10 from (72.241.213.69):
In Reply to: Farmall M Lift All Pump Removal posted by Stemmy on December 09, 2010 at 16:54:30:
I had to drop my pump by myself. I just used some dowl rod and two nuts with ratchet wrenches to lower it down. Took about 15 minutes, but it's handy if you're working alone.
third party image
third party image
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
