Re: Farmall M Lift All Pump Removal
Posted by Faster346 on December 09, 2010 at 22:04:34 from (72.241.213.69):
In Reply to: Farmall M Lift All Pump Removal posted by Pete76ny on December 09, 2010 at 16:54:30:
Not with everything installed, but in this picture, the coupler is on the right with the two washers on each end. They have a cotter key going through the washers, to hold the coupler in place.
third party image
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
