Posted by greyfoxxca on December 10, 2010 at 09:15:42 from (137.186.159.24):
In Reply to: H starting but dying posted by Hillbilly_H on December 09, 2010 at 20:54:54:
I suspect your carb float is hung up or seized. I have a w30 that does the same thing. It runs until the carb empties. After a couple of minutes the level creeps back up and I can start it again.
you can test this by unscrewing the drain on the carb and putting in a clear hose with a 1/4 pipe to tubing adapter. Hold the hose up and see there the gas level is when you turn the gas on.
Start the tractor and watch the gas level in the carb. If it drops and the tractor dies , you have to work on the float or fuel line. To see if the fuel line or supply is the issue just undo the line going into the carb and run that into a bucket using a rubber hose, for a couple of minutes. If flow stays constant the carb is the problem.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
