Re: Farmall A rod bearings
Posted by El Toro on December 10, 2010 at 12:56:15 from (108.3.200.96):
In Reply to: Farmall A rod bearings posted by 1468 Chris on December 10, 2010 at 08:36:08:
You probably should have that crankshaft measured for wear. If it is worn they may need to grind the journals. Your local auto machine shop can determine what it needs and can supply the correct bearings. Hal
