warm it up and pull the spark plugs,have it on gas side so small valves are open and you can check it this way. not sure what pres. should be but i would guess between 100-125. biggest thing is as long as they dont vary more than 10 percent. to check the small gas valves , start it up and remove spark plugs one at a time or all. just putting your thumb over plug hole , should not feel any compression leakage.if you do you have valve problem and this could be 1 cause of miss. stand to side remov ing plugs as if there is pres. on it you dont want to be shot with it. to check on diesel side you need higher guage rating like 1000 psi. compression press. should be over 400psi, in that neighbourhood. have to go through injectors i believe.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
