Re: Magneto grease
Posted by The Red on July 02, 2000 at 11:47:40 from (12.75.196.151):
In Reply to: Magneto grease posted by Jeff Again on July 02, 2000 at 11:25:21:
Wiring wise, I would use stranded 10 gauge from the Bat terminal on the regulator to the ampmeter post. You can use stranded 12 gauge wire for the field terminal and the lights.
Post A Followup
: Re: Re: Magneto grease
