Re: Bearing noise
Posted by The Red on July 02, 2000 at 12:27:52 from (12.75.196.10):
In Reply to: Bearing noise posted by George Willer on July 02, 2000 at 12:18:15:
George make sure that the 3 bolts that hold the rim on the hub are very tight. I'll bet you have a couple that are loose. I went through the same problem until I tightened those 3 bolts and nuts on each rim to around 100 footpounds on one of my Hs. That sound amplifies through the tractor frame.
Post A Followup
: Re: Re: Bearing noise
