Re: Detergent or non-detergent oil?
Posted by billde on December 10, 2010 at 19:08:26 from (72.26.92.188):
In Reply to: Detergent or non-detergent oil? posted by El Toro on December 10, 2010 at 16:16:23:
If the inside of the valve cover is dirty clean it out as well as the oilpan and use detergent oil. Using non detergent will only let more crud buil up.
