Re: Super H rear light
Posted by LarryT on December 10, 2010 at 19:17:10 from (68.35.57.27):
In Reply to: Super H rear light posted by obH on December 10, 2010 at 12:53:48:
Looked at mine. The ground wire pushes onto a tab that is attached around the mounting stud. I'd say if yours is broken off then clean a place on the inside of the case and take a Spade lug like you use for crimp on connections and strip the plastic off ans solder it to the inside. Most I have seen have broken off or corroded off and some one butcher a half a--ed temporary fix. the vibration has a tendency to break that old wire. Good Luck, LarryT
