The petcock does not come all the way out. It only opens up a bit to allow a small trickle of oil, which indicates if the oil in the oil pan is at the correct level. If you do not get a drip or a trickle, then the oil level is BELOW the petcock, and you need to add more oil until it DOES drip from the petcock.
The best oil you can put in your H is 15w/40 diesel oil because it still has the zinc additive that is needed in these old tractors. The oil that you put in your car or truck most likely does NOT have the zinc.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
