Re: starts AFTER cranking
Posted by John T on December 11, 2010 at 11:15:03 from (66.244.97.31):
In Reply to: Re: starts AFTER cranking posted by John M on December 11, 2010 at 10:34:30:
But the faster a Mag turns the more energy of a spark it creates !!!!!!! HOWEVER if the mag is spinning so fast its impulse assembly stops operating (as it should at typically a couple hundred RPM's) then she would want to kick back pretty bad because then shes firing at maybe 20 degrees BEFORE TDC. BUT thats a bit different symptom, if thats the case shes gonna buck n kick back (shes firing before TDC) as opposed to just not fire at all. This can happen (Mag ignitions) if converted to 12 volts but the 6 volt starter is retained, but its not that common and she sure acts differnt then versus she dont fire at all.
I thought we were talkin about a coil ignition system???
John T
