Re: starts AFTER cranking
Posted by mkirsch on December 11, 2010 at 11:28:21 from (67.253.216.24):
In Reply to: starts AFTER cranking posted by Dellbertt on December 11, 2010 at 04:18:33:
Nah, it's because the starter is sucking so much power off the battery, there's basically none left for the coil.
