Re: 350U Factory 12v...
Posted by CNKS on December 11, 2010 at 17:31:10 from (216.144.104.128):
In Reply to: 350U Factory 12v... posted by Dellbertt on December 11, 2010 at 08:39:06:
It makes zero difference unless you have an alternator (350 did not have one). The only other possibility is shorter VR life if it was designed only for + or - ground, and used the other way. You also need to reverse the + or - connection to the coil if changing grounds.
