Re: starts AFTER cranking
Posted by Dean Olson on December 11, 2010 at 17:35:30 from (76.31.42.124):
In Reply to: starts AFTER cranking posted by realolman on December 11, 2010 at 04:18:33:
Ok, the so the coil is not getting enough juice. What do you do about it? In my case it's a 53 SH converted to 12v with a 12v coil with no resistor needed. I am wired directly from the battery + post to the stock push pull switch to the coil. What gauge wire do recommend for that circuit? How would you check to see what amperage the stock push pull switch is letting through? That is the only thing that is not new.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
