Re: Hydaulic fluid for a Farmall 460
Posted by Wardner on December 11, 2010 at 17:45:14 from (4.154.251.218):
In Reply to: Hydaulic fluid for a Farmall 460 posted by Roger Reeves on December 11, 2010 at 17:21:22:
It may not seem like it but you have already changed the hydraulic fluid. The oil for the hydraulic system is the same oil that is used by the center section and rear frame. They are connected as well.
The IPTO is divorced, however. It has its own drain, check level, and fill locations. Use Hy-tran.
The money you just saved should be used to buy an operator's manual.
