Farmall 560D fuel pump leak
Posted by jwg on December 12, 2010 at 11:59:47 from (209.183.51.130):
The fuel pump on my tractor is leaking. I have noticed leaks around where the injector lines hook up, and on the bottom were there are two allen head screws. I believe its a Rossa-Master pump. Everything is tight. Would the pump need to be rebuilt?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
