We used to have a combination sparkplug sand blaster and spark tester in the shop that was made by AC Sparkplug Company. It had a switch that enabled you to change between a new sparkplug and the plug being tested as you watched spark intensity through a glass window. There was also an air pressure regulator that simulated compression pressure. Customers in the 1950's thought it the ultimate in high tech science!
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
