Re: (Jim) Firing Voltage versus Compression
Posted by jdemaris on December 12, 2010 at 15:25:57 from (67.142.130.25):
In Reply to: (Jim) Firing Voltage versus Compression posted by John T on December 12, 2010 at 13:50:44:
It takes 15,000 volts to fire a clean dry spark plug in open air gapped at .035" if ignition is coming from a distribor (with rotor and cap). If no rotor is involved. it takes 12,000 volts to fire the plug.
It takes only slighty more to do the same inside the engine - e.g. 1000-2000 volts more but the need can ramp up alot. Based on exactly what, I don't know. I've observed voltage increase, but cannot say I ever had any of knowing if it's due to higher compression, or a fuel-rich environment, etc.
