Re: Farmall 460, gears not meshing right
Posted by Bud DeLong on December 12, 2010 at 16:54:42 from (64.12.116.73):
In Reply to: Farmall 460, gears not meshing right posted by Tod Michigan on December 12, 2010 at 13:26:47:
After getting a 460D going with much help from this forum the hyd was next! Found the bolt had come out of the holder on the end og the large gear that drives the gear on the pump allowing big gear to slip back. The fix was through a large plug hole straght in front of the large gear! New bolt with locktite and on to the next problem,sealing! I hope this helps?? Good luck! Bud.
