Re: M fan belt
Posted by john d on December 12, 2010 at 18:21:23 from (69.11.149.9):
In Reply to: M fan belt posted by Sammy in Kansas on December 12, 2010 at 14:31:47:
Loosen the locknut on the setscrew that's in the front half of the pulley hub on the waterpump/fan hub. Remove the entire setscrew. Squirt some Gumout or other spray cleaner into the setscrew hole, and let it attack the dirt/crud that has accumulated in the 20 years or more since that belt was replaced the last time. Brush the threads on the front of the hub with a wire brush to clean them. Use a brass drift punch and a hammer to TAP on the raised boss on the hub in an attempt to make it move in either direction. Do NOT lose patience and HIT that thing with a big hammer! Once you get it to move, rock it back and forth, then tighten the belt by rotating the pulley halves together. Replace the setscrew, making sure the end of it goes in the groove on the inner part of the assembly. Tighten the locknut.
The belt does not have to be extremely tight to work well.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
