I had the original rod that was bent in multiple places and just didn't look good. I made a new rod from 5/16" rod. Threaded one end and bent the other and drilled a cotter key hole. I installed the bracket with the rod through it and installed the bent end to the pivot. That section from the center bracket forward is straight. I eyeballed the threaded end and made that bend till it looked like it was inline with the crank. Disasembled and treaded into the crank. It threaded right in but was too hard to crank. It took several more attempts to get the rod bent so I had no tension and it cranked easily. I did chase the threads in the crank with a tap and use a die on the treaded rod, once cleaned up lightly grease. Do all of this before you hook up the shutters.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
