You may have a voltage drop when you pull the starter in.Check the battery voltage at the posts before you attempt to start and then test at the posts when the starter is engaged. If your battery cables are good there shouldn't have more than 1-2 volt drop when the starter is engaged. If the connections are corroded or the cable has interior corrosion you may be dropping the voltage at the coil too much to get a good spark when the starter is engaged Clean all your battery connections. Another suggestion is check the timing you may have the spark a few degrees too advanced to allow it to start with the starter
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
