Re: Farmall M (carburetors)
Posted by gene bender on December 13, 2010 at 02:58:17 from (67.55.227.196):
In Reply to: Farmall M (carburetors) posted by Brent Zappe on December 12, 2010 at 20:39:32:
Sounds like your guy messed up a good carb. If your is the original dual fuel carb just how did it start on gas then switch to fuel when warm with the same carb . Point there is no changing of the carb to gasolene. Get your 'friend' to get your carb so it will run as he screwed it up so he should fix it back.
