Posted by rustyfarmall on December 13, 2010 at 07:39:40 from (209.152.78.140):
In Reply to: Wont Run posted by Faster346 on December 13, 2010 at 07:12:17:
There is also a fine mesh filtering screen inside the carburetor. It is attached to the brass fitting where the fuel line attaches. Use a 5/8" wrench and remove that fitting and clean the screen. If that doesn't cure it, you need to dig into the carburetor itself.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
