Re: IH 434 / oil in right side brakes
Posted by troy schubert on December 13, 2010 at 10:44:20 from (63.166.241.80):
In Reply to: IH 434 / oil in right side brakes posted by Troy Schubert on December 12, 2010 at 12:35:54:
thanks all for your replies
update:where the spline shaft for brakes comes out of the casting, there is a approx 10" diameter metal plate (brake pad and brake assy interface with this). plate is held on by 6 bolts, however, 2 rear bolt heads are broke off (sabotaged for sure!) I have some work to do to fix that and I want to remove this brake plate entirely to clean and reseal to the rear casting. However, plate will not come off. It seems the spline shaft is holding it on. Only way I figure the spline shaft can come out is if I go inside the rear differential? Need a double shot of courage for this.
pls give a shout if I"m missing some important point here or if you can recommend a better approach. I guess I could try to seal it back up without removing the plate (once I fix the bolts), but I can only get about 1/8" gap between the plate and rear casting. hardly enough to do a good job at cleaning and sealing.
to be cont"d...
