Re: Farmall M (carburetors)
Posted by rustyfarmall on December 13, 2010 at 10:56:57 from (209.152.78.140):
In Reply to: Farmall M (carburetors) posted by Stuart on December 12, 2010 at 20:39:32:
Make sure the float valve and seat are nice and clean, the seat is screwed down tight against a GOOD gasket, make sure the float does not have a pinhole in it and that it is adjusted according to specs for both the height and drop. (no fudging) Also, make double sure that the float is not rubbing or dragging on the sides of the fuel bowl. A carburetor is a PRECISION instrument. Treat it as such and you will be rewarded.
