Re: ih 300 utility carberator problems
Posted by Dellbertt on December 13, 2010 at 16:03:03 from (209.172.21.87):
In Reply to: ih 300 utility carberator problems posted by roosterdooster on December 13, 2010 at 15:42:56:
Did it start before you cleaned carb.
Is it turning over fast enough.
Try starting with air filter disconnected.
Remove main jet and blow it out of with small wire.
Sitting could be low compression. Pull it to start and let it run for awhile it may bring itself back.
Dell
